05-19-2006 09:54 AM
05-19-2006 10:07 AM
Do
Call SudDlgShow("Dlg1","C:\test.sud")
Select Case DlgState
Case "IDOk" : MsgBox "OK"
Case "IDCancel" : MsgBox "Cancel"
End Select
Loop While DlgState<>"IDOk"
You also can use the click event for the buttons to show up the dialogs.Matthias Alleweldt Project Engineer / Projektingenieur | Twigeater? |
05-22-2006 02:13 AM
Hello Matthias,
thanks for your answer.
Who does make up that stuff and it is not even written down in the help?!
Thomas
05-22-2006 09:14 AM
Actually, it is in the help:
Brad Turpin
DIAdem Product Support Engineer
05-22-2006 09:17 AM
OK,
So the pretty pictures only show up on my computer. If you look in the help for "SudDlgShow()", you will find a description of the "Return Parameter" called "DlgState". If you click on that link, it lists the allowed values of "DlgState", which Matthias used in his answer.
Brad Turpin
05-22-2006 09:30 AM
05-23-2006 03:11 AM - edited 05-23-2006 03:11 AM
Message Edité par tom_the_dude le 05-23-2006 03:12 AM
05-23-2006 03:21 AM
05-23-2006 04:09 AM
Hello Matthias,
oh yes, it's true. I can do stuff from my dialog but just this command does not work. So I have to have something wrong in the whole process.
Have to check it.
Thank you!
Thomas
05-23-2006 09:03 AM
Hi Tom,
In answer to your question about why NI implemented the SUDialog interface the way they did-- in a word... licensing. NI does not own the rights to Visual Basic, which does indeed have a lovely form editor. We could have used VB or VBA as the automation language and custom GUI engine for DIAdem, but then we would have had to pay a licensing fee for each copy of DIAdem, and then your version of DIAdem would have been noticeably more expensive.
Brad Turpin
