DIAdem
How to get channel Index
Hello DIAdem Users,
I want to look for a particular string in the Channel's name and once I find that string in a channel'sname then I want to have its index. How can I achieve that?
Regards
(4,968 Views)
Accepted by topic author Sarry
Option Explicit
dim groupObj : for each groupObj in data.root.ChannelGroups
  dim chObj : for each chObj in groupObj.channels
    if 0 <> inStr(1, chObj.Name, "ei", vbTextCompare) then
      MsgBox chObj.Name & " " & chObj.ChannelGroup.Properties("index").Value & " " & chObj.Properties("groupindex").Value
    end if
  Next
Next
To determine the code to read such properties, you can just drag and drop it from property window into script.
(4,966 Views)
Thank you!!!
(4,949 Views)
