10-22-2014 12:21 AM
Hello
for some unknown reasons some of my tdms-files have different icons when I open the tdms files in Diadem. Some have
a sandglass icon and only change the icon when I click on the "+" symbol of the file itself.
Does anyone know this issue and how can I solve it automatically in order not having any sandglass icons anymore?
thanks in advance
Solved! Go to Solution.
10-23-2014 04:53 AM
Hi Norick,
the hourglass means that these files are beeing indicated by the datafinder. This might take a while.
If you update the view (F5), they should appear like the other files. This is also what happens when you press the plus.
Cheers, RMathews
10-23-2014 05:01 AM
Hello Mathews
thanks for the response. Is it possible to do it automatically in Diadem or with a Labview code?
cheers
10-23-2014 06:15 AM
You can try searching the web how to send via VBScript a F5 command and use that in SCRIPT.
For LabVIEW here you have an example.
10-30-2014 12:16 PM
Hi Norick_17,
the hourglass is presented for the case DataFinder did not already index these files.
This could be of several reasons:
Greetings from cloudy Aachen
Stefan
10-31-2014 01:43 AM
Hello Stefan
this is exactly the solution I was looking for 🙂
Thanks a lot!
11-05-2014 02:46 AM
Stefan
is there a way to update (refresh) the tdms files from Labview as well? How can I do it?
The problem is, that I can not find specific data in the tdms files from Labview due to the problem that the tdms-file(s) are not yet
indexed. In other words I would like to update (refresh) all tdms-files automatically without opening Diadem first and run a script
file for example.
best regards
11-11-2014 03:54 PM
Hi Norick,
Do you have the LabVIEW DataFinder Toolkit?
Brad Turpin
DIAdem Product Support Engineer
11-12-2014 12:21 AM
Hi Brad
yes I have.
11-12-2014 07:58 AM
Hi Norick,
You should be able to use the "Index File" or "Index Folder" method of the Invoke Node on the LabVIEW DataFinder Toolkit palette to "nudge" the files you want to index.
Brad Turpin
