08-23-2007 08:32 PM
08-24-2007 09:53 AM
Hi YangAfreet,
All tables in DIAdem VIEW and REPORT display the values in specific Channels in the Data Portal (or in rare cases the values of a global array variable). So if you want to change the value of a particular cell in your table, you need to change the value of that particular cell in the data channel being displayed in that table column. This you can do with the ChV() function in a VBScript, or you can change that value interactively in a VIEW table.
Of course, if you're talking about a table in a SUDialog, then there is a way to address and edit individual table cells, but my guess is that this is not the sort of table you're talking about.
Brad Turpin
DIAdem Product Support Engineer
