02-23-2012 09:13 AM
Hello!
My Problem is: I'm trying to start an exe-file by clicking a button within a SUD-Dialog. Does anybody know how to realize that?
For example: Run("C:\Windows\Notepad.exe") ?!
Thanks!
Solved! Go to Solution.
02-24-2012 02:03 AM
dim command : command = "notepad.exe"
dim shell : Set shell = CreateObject("WScript.Shell")
dim status : status = shell.Run(command, 1, true)
If 0 <> status Then
Err.Raise 6, "", "Command returned error!"
End If
should do the job.
02-24-2012 05:08 AM
Thanks for you reply!
Your code worked so far to start Notepad.exe but what I'm trying to do is to start a file, located one folder above my script folder.
I tried the following...
dim command : command = "Script Assistent\TSM Script Assistent.NET.exe"
If
0 <> status ThenErr.Raise6, "", "Command returned error!"
End If
...but then I receive an error message :-/
The script and the sud-file is located in:
G:\Script\Scriptfile.vbs + Dialogfile.sud
The exe I'm trying to start is here:
G:\Script\Script Assistent\TSM Script Assistent.NET.exe
What's wrong with that?
02-24-2012 05:26 AM
For my understanding: Can I check my "command" by typing it into the command line window in windows?
02-24-2012 06:47 AM
dim command : command = """" & Dialog.FilePath & "Script Assistent\TSM Script Assistent.NET.exe" & """"
If 0 <> status Then
End If
Dialog.FilePath conatins the path of the sud file.
Because the command contains spaces it is important to put it into ".
02-24-2012 09:34 AM
Hi Guys,
Another option is to use the DIAdem command "ExtProgram", though in all cases you'll need double-quote characters in the command if your file path has spaces-- that's a Windows requirement.
Brad Turpin
DIAdem Product Support Engineer
02-27-2012 06:36 AM
Hello!
Thanks for your reply AndreasK, you solved my problem!
I will try the "ExtProgram" variant in future.
Regards
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
