06-02-2006 03:45 PM
06-07-2006 09:44 AM
Hi Rich,
DIAdem has a built-in Excel Export Wizard, which you can fully automate with VBScript, and you can also use the VBScript Recorder to create the automating VBScript code as you interactively manipulate the wizard. DIAdem can also instantiate various Excel AxtiveX objects with the CreateObject() function and push values to cells, etc., as you propose. DIAdem also allows itself to be automated by external compilers with its two ActiveX servers (DIAdem.ToCommand and DIAdem.ToDataSheet). If you search on these OLE server names in the DIAdem online help, you will find a full description of their properties and methods.
I mentioned your difficulties with the TDM Excel Add-in and large TDM files, and R&D ran a series of tests, which all performed flawlessly on their computers:
1). One TDM file with one channel, 80MBytes, more than 65K lines for one worksheet.
2). One TDM file with several channels with same length, 160MBytes, more than 65K lines for one worksheet.
3). One TDM file with several channels with different lengths, 170MBytes, some channels more than 65K lines, some not.
R&D and I are hoping you will post one of your troublemaking TDM (and TDX) files on our ftp.ni.com/incoming ftp server so that we can try it here. The TDM Excel Add-in is designed to offer you a choice of which rows to load when your data file has channels longer than the current 65,536 row limit that Excel has, so you're really not supposed to be having these difficulties.
Please do send over that big TDM/TDX file,
Brad Turpin
DIAdem Product Support Engineer
06-07-2006 10:00 AM
06-07-2006 11:41 AM
Hi Rich,
I have duplicated your Excel loading error on my computer. The TDM file loads fine into DIAdem, though, where it becomes obvious that there are 31 Groups!
I have forwarded this TDM file on to R&D and asked them to look into it. Perhaps there is a limit to the number of Groups that can be imported into Excel with the Add-in. How many worksheets can Excel have open at one time?
More soon,
Brad Turpin
06-07-2006 12:22 PM
06-09-2006 10:26 AM
Hi Rich,
Yeah, after I posted last time I tried creating more than 32 sheets in Excel manually and it worked fine. I heard back from R&D today, though, and the issue wasn't too different. It turns out that Excel only allows you to name a sheet with 32 characters, and some of your group names had differences after the 32nd character, for example:
PnC 50% SOC 250A, 10 sec Discharge pulse, Bitrode Step 45
PnC 50% SOC 250A, 10 sec Discharge pulse, Bitrode Step 46
So Excel threw the error when the TDM Excel Add-in tried to name the "46" sheet, because from Excel's point of view it was trying to create 2 sheets with the name
R&D has created a new version of the TDM Excel Add-in which checks for this issue and indexes the Excel sheet names as best as it can. Note that neither LabVIEW nor DIAdem have any issues with these names, this is purely an Excel limitation to its sheet names.
Give this version a try,
Brad Turpin
06-14-2006 08:37 AM
