03-17-2016 05:23 AM - last edited on 03-24-2016 09:34 AM by LiliMcDonald
HI all,
I'm trying to load CSV files with DIAdem 2014, and I found there is a great tool, 'DataPlugin'.
However, with CSV DataPlugin tool, there is critical problem with my data files. (See attached picture)
As you can see the attached sample CSV file, it includes many lines with different columns.
And here, DataPlugin reads the number of columns of 1st line (e.g.: 4 columns), and set it as the number of columns to read.
So I cannot load the whole data(e.g.: 53 columns) if the data of first line has columns less than that.
Can anyone recommend any approach, please?
With best regards,
Young
Admin Note 3/24/16: Files removed per user's request
Solved! Go to Solution.
03-17-2016 11:31 AM
Your file seems to be a buslog file.
Is there a binary soure file that might be readable with an existing dataplugin or the buslog converter.
I would assume that beeing able to read the file is only half the truth.
At the end you need one group for each distincted Start Text.
Is this true?
03-17-2016 06:55 PM
Andreas,
I don't think there's source file that is readable with existing plugins.
And for the rest part of your answers seem quite difficult for me. I'll be thankful if you can explain with a little more specific words..
Anyways thanks for your comment.
03-18-2016 02:48 AM
I just add some lines of script and attach the related dataplugin. (I just added the code to have a direct look.)
The uri file is intalled by double click and will show up as new load type in the diadem file dialog.
It would be nice if you could provide some information how the data was created. Maybe we can add it as official plugin to our DataPlugin web page.
Option Explicit Sub ReadStore(File) File.Formatter.Delimiters = "," File.Formatter.LineFeeds = VBLf File.Formatter.DecimalPoint = "." dim startLine : startLine = file.GetNextLine() if 1 <> instr(startLine, "[Tenergy Bus Log Data]") then call RaiseError() end if While not File.Position = File.Size dim groupName : groupName = file.GetNextStringValue(eString) if not root.ChannelGroups.Exists(groupName) then root.ChannelGroups.Add(groupName) end if dim grp : set grp = root.ChannelGroups(groupName) dim i : i = 1 do while true dim val : val = file.GetNextStringValue(eR64) if isempty(val) then exit do end if if grp.Channels.count < i then call grp.Channels.Add("Ch_" & i, eR64) end if dim chObj : set chObj = grp.Channels(i) chObj.Values(chObj.Size + 1) = val i = i + 1 loop Call File.SkipLine() wend End Sub
03-20-2016 09:37 PM
Thanks very much for your assistance, Andreas K.
It works well with my software, and seems to be nice script which can be modified for future applications.
Anyways, the related tasks will take some time to proceed further, so I'll let you know if we think we should add this to Dataplugin web page.
Thanks again.
