05-01-2007 02:32 PM
05-02-2007 11:27 AM
Hi Craig,
If you want to apply different manual scaling parameters to each of the stacked Y axes, then you need to use 3 separate Y axes. If you want to display a curve-specific text to each of the stacked graphs, this you can do with a DIAdem expression:
@ChnName(CCN)@@ channel name of each curve
@ChnDim(CCN)@@ channel unit of each curve
@ChnComment(CCN)@@ channel description of each curve
The corresponding value for each curve will automatically display at the correct vertical spot next to its curve.
Brad Turpin
DIAdem Product Support Engineer
