04-11-2007 06:28 AM
04-11-2007 09:56 AM
04-11-2007 01:19 PM
04-27-2007 02:07 PM
If your VRML consists of separate objects then you can right click on an object and click on the select a group of points to just highlight the points that make up one object. If your VRML does not have the different parts separated as different objects then you must select each point individually (CTL - click to select a point). I would like to discuss the details of this application so I can make sure you get the assistance you need.
VRML models must be VRML 97 or 2.0 to work in INSIGHT. I often find that VRML models from many of the major CAD packages have multiple duplicate surfaces and points and must be cleaned to properly be used within INSIGHT. I have used a packaged called Accutrans 3D in the past to do this as it is an inexpensive package. There are other similar tools available that could be used as well. There is a conversion tool that installs with INSIGHT (called VRML Optimizer) that will eliminate many duplicate points and surfaces but it also combines all objects in the VRML into one object.
04-29-2007 05:49 AM
