Try out this little script.
(Tested whith Diadem 9.1 and 10.1) Can anyboby tell me, what's going on
here? Is the GroupPropGet-function unable to read some special strings?
Remark, that the grouppropperty "test1" will be set correctly.
Has anybody a workarround? I use Groupproppertys of type string to save
additional parameters of experiment. Should I say to my cutomers "Don't
use "100D10000" and "100E10000" and a lot of other combinations as name
of your samples?"
Use GroupPropValSet / GroupPropValGet instead and everything works fine (in 10.1). The other versions were introduced with 9 and implemented in a not verry flexible way. This was improved in 10 but for compatible reasons the old version stayed alive.
Thanks Matthias,
"GroupPropValGet" instead of "GroupPropGet" works for Diadem 10. But I
need a workarround for Diadem 9 because this version is running by
customer. Is there any other way to read a Grouppropperty of type
string than GroupPropGet?
The solution I see is to add an non-numeric letter at the first place and cut it off on every read. I tried it with a '@' and this worked. Perhaps you have to make a command extension function to show the values in a layout. Is this possible and a solution for your application?
