01-24-2007 08:34 AM
01-25-2007 09:33 AM
Hi Bastian,
If you export anything from REPORT to Word, then you are sending a picture, and there is no way in DIAdem to specify that the size of a particular text inside that picture be a specific font size. This is because the font sizes in DIAdem REPORT are all relative. All REPORT text belongs to an object which can be arbitrarily resized, causing the text inside it to also be arbitrarily resized. Even the overall REPORT window can be resized and have its aspect ratio (landscape/portrait/arbitrary) changed, so if you're sending anything from REPORT, then that is a dead stop. If instead you are sending a Data Portal channel to a Word table via ActiveX, then you should be able to set the Word table font size property to a particular size, assuming of course you can find that property in the MS object model. I could dig up an example of this, but I don't remember if the example had that font size property in it.
Which were you thinking of?
Brad Turpin
DIAdem Product Support Engineer
01-25-2007 11:13 AM
01-26-2007 04:56 PM
Hi Bastian,
You can only send data channels from the Data Portal to Word via AxtiveX into a Word TABLE. There's no way to send it to a Word graph. So if you want a graph of the DIAdem data, you'll just have to send a picture of that DIAdem graph from REPORT to Word.
Brad Turpin
01-30-2007 04:09 AM
