DIAdem
Generating Sine Wave
Hello all,
I have been using DIAdem lately to discard certain sections of noisy data in a channel. I have been doing this by comparing the fundamenal waveform of the data to a filtered waveform. I have it working the way I want, but I currently have to pull in a "fundamental" tdms file that I create with LabVIEW using the harmonics analysis vi. I have successfully managed to extract the fundamental frequency, amplitude, and phase shift of the waveform using the Single Tone Extract command in DIAdem. My questions are as follows:
1.) Is there anyway in DIAdem to generate a sine wave using the fundamental frequency, amplitude, and phase shift that I have returned?
2.) Is there another funciton or command that would result in this fundamental sine wave (similar to the harmonics analysis in LabVIEW).
Thanks for your help.
-Kyle
(3,026 Views)
Kyle,
Have you looked into generating channel data? There are a few built in examples that should point you in the right direction. One such example is called "Generating Channels and Groups with a Script". You could then use the "sin()" function to fill out the data of the channel.
(2,969 Views)
