DIAdem
For Loop Problem
I have a for loop that seems to be giving me inconsistant results.  It doesn't seem to execute the correct number of times.  Here is my code:
    a = Min
    CRange = ((Max - Min) * 10) + 1
    For x = 1 To CRange
      ChD(x, PhaseRange) = a
      a = a + 0.1
    Next
Min and Max are values that contain up to one decimal place.  Given a certain set of data I had a Min of 0.8 and a Max of 1.  Now the purpose of this loop is to count the difference between Min and Max in 0.1 increments.  So for the values listed I would have 0.8, 0.9, and 1.0.  The statement CRange = ((Max - Min) * 10) + 1 should return 3 and it does.  I've confirmed this with the debugger.  Now I would expect the For Loop to cycle through 3 times but it doesn't.  It only executes twice and then carries on.  I thought maybe it had something to do with Min and Max being floats so I converted CRange into an integer using Int() but that didn't help either.  What is really boggling me is that for a different set of data with a different range (0.2-1.8) the Loop executes the correct number of times (17).
Can anyone shed some light onto this?  I'm at my wits end.
(3,153 Views)
Hello Pat_Cas!
You was right the problem is that CRange is a float. The command int() only cut off the decimal places but the result is still a float. If you use the command trunc() instead the loop will work.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(3,140 Views)
Ah, you have saved my sanity.
You sir, are a gentleman and a scholar.
(3,133 Views)
