DIAdem
Find all indices of a string in text channel
I have text channels; each has some values containing the word "Shutdown". I would like to determine all the indices of those values. I tried ChnFind method but it was not successful. Please check the following code:
  for each oGrp in Data.Root.ChannelGroups
    ChnString = oGrp.Channels("Description").GetReference(eRefTypeNameName)
    Ind = 1
while Ind <> 0 Ind = ChnFind("Ch(ChnString)" & " contains " & """Shutdown""", Ind) wend next
PNo method can do the right job but it can only detect the first value.
I wonder if there is a method able to search string and support wildcards. It will be very helpful in this case.
Thank you
(3,609 Views)
I'm using Calculate function. In my case, when in one column (channel) string "0x36" occures, I copy from other column (channel) the corresponding value (which is located in the same row as required string), and create new channel with copied values, which only correspond to this found string. You can see example below:
Call Calculate("Ch(""[3]/Re0_P"")=IIf(Ch(""[1]/addr"")=""0x36"",Ch(""[1]/Re0_P""),NOVALUE)",NULL,NULL,"")
Ch(""[3]/Re0_P"") --> new channel with copied values
Ch(""[1]/addr"") --> channel with strings
Ch(""[1]/Re0_P"") --> channel with corresponding values
(3,561 Views)
Thank you for your idea. Using IIF is a good one.
However in my case, I want to detect the word "Shutdown" in all the string values of channel; this word is just a part of those interested string values. For example, I want to detect strings like:
"System_Shutdown"
"Engine_A_Shutdown"
"Temp_Shutdown"
"Shutdown_Ctrl"...
Direct comparison using "=" is not appropriate for my case.
(3,548 Views)
Accepted by topic author levan8421
I didn't have enough time to check it, but I found some discussions on StackOverflow about how to find substring in a string:
https://stackoverflow.com/questions/15585058/check-if-a-string-contains-another-string
https://stackoverflow.com/questions/2543225/how-to-get-a-particular-part-of-a-string
Maybe this will be helpful. I would be also interested how to do it in a smart and quick way. Maybe someone from DIAdem Support can answer this question.
In DIAdem you can search for InStr for VBS:
vInStr = Object.InStr(start, string, string2, [compare])
(3,529 Views)
