11-27-2006 08:28 AM
11-28-2006 08:20 AM
Hi Robert,
Have you tried the "ADO" DataPlugin at www.ni.com/dataplugins? This will load any Excel file into DIAdem, making the assumption that each column should be a channel.
Brad Turpin
DIAdem Product Support Engineer
11-28-2006 08:54 AM
11-29-2006 09:24 AM
Hi Robert,
There is no way to automate the creation of the STP file that I know of, short of using ASCII commands to build up the STP file from scratch, and I don't have any information as to the structure and contents of the STP file. I know some customers have worked on this with the ASCII Wizard and resulting STP files, but I don't know how to help you do it.
If your Excel files are not too big, you, might consider instead building the desired intelligence into an import script or a DataPlugin, and in both cases it could be built on either ADO technology or ActiveX technology. With this approach you could evaluate cell-by-cell and reject any empty cells or import the file differently depending on what values you find in particular cells.
Brad Turpin
