02-10-2014 12:27 AM
Pls find the attached excel data which contains section name and date as the first two columns. If I delete these 2 columns, I am able to load the data using plugin wizard without any problem. If I try to load without deleting these two columns, I am not able to load it properly. Pls help me in loading the entire data without truncation as the date and section name is very important for me.
X. Ignatius
02-10-2014 05:17 AM
The reason that the Excel wizard is not able to open the file is that it is not an Excel file, but a CSV file with XLS extension.
Instead you can use the Text DataPlugin Wizard to create a DataPlugin for your files.
02-10-2014 07:52 AM
Dear USAC,
I tried opening using ascii csv plugin. It opened but I am not able to view the date column which is in the file. My ultimate aim is to plot the date(X-axis) vs different channel(Y-axis). Is this possible with the file attached?
X. Ignatius
02-10-2014 09:51 AM
Hi Igni,
Please see my answer and posted DataPlugin at your other duplicate post.
http://forums.ni.com/t5/DIAdem/Excel-data-loading/m-p/2733695/highlight/false#M18209
Brad Turpin
DIAdem Product Support Engineer
