10-16-2013 08:54 AM
Hi
i have problems to save my changed Excel File.
Diadem open my Excesheet, bring the "22"in to the Sheet and i close the excel without saving.
I coulnd´t found my mistake and couldn´t found some information on this forum / google / ...
Maybe some one has a idea!
Thanks a lot 🙂
Option Explicit 'Erzwingt die explizite Deklaration aller Variablen in einem Script. Dim ExcelApp, ExcelSheet Const ExcelMaximized =&HFFFFEFD7 ' Start Excel via OLE. - A new Excel instance always starts. Set ExcelApp = CreateObject("Excel.Application") ExcelApp.Visible = True ' True = Show ExcelApp. False = Hide ExcelApp. ExcelApp.WindowState = ExcelMaximized ' Maximize Excel window. ExcelApp.Workbooks.Open("c:\temp\_Test.xlsx") ' Open prepared DIAdem table in Excel. Set ExcelSheet = ExcelApp.Sheets("NIO_Files") ExcelSheet.Cells(2,1).Value = 22 'DemoNumber '?????????????? ExcelSheet.Parent.Saved = True ExcelApp.Quit ' In VBS, Excel must be closed explicitly. Set ExcelSheet = Nothing Set ExcelApp = Nothing
10-17-2013 01:15 AM
New Day - new google - got ist 😛
ExcelApp.ActiveWorkbook.Save
but i couldn´t find a overview about all the commands you can send to excel.
what helped me was to record a makro an look what happen in excel 😉
10-17-2013 03:41 AM
Hi MaikThierer,
a list of all available commands is only supported by microsoft.
You have to be carefull between available commands "inside" Excel and the available commands published to ActiceX/OLE. There might be a difference.
Philipp K.
AE | NI Germany
11-26-2015 09:28 AM
Need help on a similar situation.
What I want is, after opening an excel through diadem, make changes in it and then save the opened excel as a text file.
I modified the script line as given below;
ExcelApp.ActiveWorkbook.SaveAs ("c:\temp\_Test.txt")
The script file runs successfully saving the text file and text file opens properly but the data inside is not correct.
Does anyone know method to solve this?
Fazil.
11-26-2015 11:16 AM - edited 11-26-2015 11:19 AM
Got it.
Should modify as given below;
ExcelApp.ActiveWorkbook.SaveAs"c:\temp\_Test.txt",20
The number 20 is XlFileFormat Enumeration Value for text format (refer: https://msdn.microsoft.com/en-us/library/office/ff198017.aspx)
Fazil
