04-18-2006 01:31 PM
04-19-2006 09:49 AM
Hi jbrandim,
What happens if you take that Excel file created by DIAdem 8.1 and try to open it in an older version of Excel? Presumably this used to work fine for you prior to Excel 2003. Does it still? If it does still work, what happens if you then resave this imported Excel file with the older version of Excel. Can this new (resaved) Excel file be opened in Excel 2003?
The new Excel export code that is working correctly for you in DIAdem 9.1 will likely have trouble running in DIAdem 8.1. You could try replacing the "...DIAdem\AddInfo\gfsexcel.dll" in the DIAdem 8.1 directory with the new file from the DIAdem 9.1 directory, but there are no guarantees. You should save a backup version of the dll in case it doesn't work.
Brad Turpin
DIAdem Product Support Engineer
04-21-2006 01:29 PM
Thanks for the suggestions Brad.
I tried taking some of the files produced by Diadem 8.1 to another PC where we still have Office 2000 installed. Excel 2000 cannot open the files either.
I also tried replacing 8.1's "gfsexcel.dll" with 9.1's version. That mostly works. It exports all actually data correctly. It does not populate colums that come from implicit channels.
If need be, we can live with that until we migrate to a newer version.
