DIAdem
Event Change issue in Dialog Box.
Hi All,
   I'm having a problem with a user dialog box. The Dialog should be using eventchange to update certain aspects of the dialog box based on a user selection in a combo box. The porblem I'm encountering is that eventchange does not recognize the change from no slection to the first selection. IE a user would have to select something else first then change to what they want for it to be recognized. Is there a better event that would resolve this issue? or is the issue something else entirely?
Artemis
(3,822 Views)
Accepted by topic author Artemis125
Hey Artemis,
The easiest solution would be to use the EventInitialize event to set the combo box to a default value when the dialogue box opens, and your dialog box settings to match that selection.  That way the first change the user makes would trigger value change.
Britton C.
Senior Software Engineer
(3,805 Views)
Could you send an example of how to do that? I haven't been able to fix the issue with it yet.
(3,780 Views)
Figured it out. Thanks for the help!
(3,765 Views)
