DIAdem
Error ploting contour graphic and create matrix from vectors
Hi.
I'm working with a few (64 exactly) AutoSpectrum channels where all have the same channel length, 1048576 measures. I have too a Frecuency channel that have the same length as AutoSpecrum.
I want to plot a contour graphic, so in Display i choose Matrix option. In "X-channel" I choose the Frecuency channel. In "Y-channel" i choose a numeric channel that I create (From 1 to 64, with 64 values) that represent the number of AutoSpectrum I have. FInally in "Z-matrix" I choose all AutoSpectrum channels. But when I click on OK to plot the contour graphic, DIAdem crashes.
First i think it could be because i choose too many channels with a high number of measurements, but if I choose only 2 channels to show (And in "Y-channel" I put obviously a numeric channel with only 2 values) i continues crashing. Only when i plot one AutoSpectrum channel it works.
What I'm doing wrong ?
How can I create a matrix where each row contains values of each AutoSpectrum ?
Thank you for your pattience. Bye.
(4,835 Views)
Hi Haritzodri,
It sounds like you have too much data to plot.  if every data point across all 64 channels was drawn as a pixel on your screen, you would need more than 67 million pixels.  Most screen resolutions have no more than a couple of million pixels.  Consider as well that each of those data values is stored as an 8 byte double in DIAdem, and you're asking to plot half a GB of data on a 3D graph.
I recommend that you apply data reduction to your 64x1048576 matrix to get it down to something more like 64x1024.  That would mean averaging 1000 contiguous values into a single Z value.  You can use the "Linear Mapping" ANALYSIS function in the Channel Functions palette to apply that data reduction.
Brad Turpin
DIAdem Product Support Engineer
(4,735 Views)
Hi Brad,
Thank you for the reply, it works.
Bye.
Haritz
(4,720 Views)
