06-25-2007 08:42 AM - edited 06-25-2007 08:42 AM
Message Edited by swillh on 06-25-2007 08:55 AM
06-26-2007 04:13 PM
06-26-2007 06:23 PM
06-27-2007 03:01 PM
Hello swillh,
I don't have any suggestions for you based on the information I have at this point. Can you post the text to the .aut file so I can take a look at what you are doing?
06-29-2007 03:20 PM
Hi swillh,
I also would like to help you.
Unfortunately, The reported access violation in the central Windows ntdll.dll is very unspecific.
May be the following questions will help you to provide me more info.
1. You mentioned that the aut's and - I think - also the accessed text file reside on a server.
Is there a stable network connection?
Are the files accessed by multiple clients simultaneously?
Is the text file read by one client while another client is writing the same file?
2. Have you already tested opening the file with the FileOpen command before calling FR?
Do you see any chance to convert the aut to a vbs file? This gives you more alternatives in accessing text files.
3. What do you mean with "processing ATD's with 30 or more channels of data"? Where is the relation between ATD files and data channels?
Christian
07-09-2007 08:43 AM - edited 07-09-2007 08:43 AM
Christian,
I will answer your questions in the text below. Thanks for your help.
Hi swillh,
The server can sometimes be a little slow but the connection is good. This computer is using the same connection that the prior computer utilized without issue.
It is possible that more than one computer can be accessing the same file, but again, this has never been an issue. We are reading the files only, not writing to them.
The processing routines we are running have used for over 5 years without any issues until adding this computer.
No, files are "read only"
Yes
Processing Crash Dummy data with file sets low in channel count (15 channels) result in successful processing without any crashes or access errors. When processing dummies with more than 20 channels we sometimes encounter these issues. The higher channel count may be the only common factor I can find in these faults.
Steve
Message Edited by swillh on 07-09-2007 08:44 AM
07-10-2007 02:52 AM
10-15-2007 02:44 PM
I am experiencing a similar problem using DIAdem 10.1 (SP1) on a group of computers (I have not figured out a pattern yet). This is what happens:
Error type: ACCESS VIOLATION
Error address: 0003326D
Module name:ntdll.dll
The only remedy is to close and re-open DIAdem, which is frustrating. I have not tried to uninstall/re-install DIAdem yet, and am hoping for other ideas first?
Thank you,
Julia Moeller
10-16-2007 06:28 AM
10-16-2007 12:41 PM
Hi Christian,
Thank you for your reply. I have information from two computers that are experiencing this problem. Their information is:
Pentium(R) D CPU 3.4 GHz 3.39 GHz, .99 GB Ram
I am also sending a DDD file. I have a computer with more than 2GB RAM and have not yet experienced this problem. The only special configuration is that DIAdem is starting with a User Command script, that declares some global variables and subroutines. Please let me know if more information would be helpful,
Julia
