08-12-2011 02:56 AM
Trying to open a tdms-file error 2507 "Invalid Object Id" shows.
No idea about the reason, because the same vi already has generated several tdms-files and only one of them can not be opened.
Does anybody know a way to read this (important!) data, maybe at least a part of it, or are they completely lost?
Many thanks for every help.
08-15-2011 01:09 AM
Hi Mrnew,
Is that possible for you to post the TDMS file here and I would like to take into this problem you have.
Thanks.
Yongqing Ye
NI R&D
08-16-2011 12:32 AM
Hello Yongqing Ye,
Thanks a lot for your kind offer. Yesterday, a colleague of mine told me a solution: I had to delete the index file (tdms_index) first, and then try again to open the tdms-file. It worked!
So, probably the index-file was corrupt and DIADEM is able to generate a new index-file when there is none. (But only then)
Thanks again and bye, bye
