hi there,
I'm using Diadem version 9.1 and I tried using the function ChnOrdAFCalc to do an order anlysis on my data values. The parameters which I've set are:
OrdAFType = "Order"
OrdAFMaxOrder = 16
OrdAFFiltReCalc = 50
OrdAFSigWeight = "None"
GenXBegin = 0
GenXEnd = 3000
OrdAFRevolStep = 100
OrdAFFFTLength = 1024
FFTAmplType = "Ampl.RMS"
FFTAmplExt = "No"
FFTWndFct = "FlatTop"
FFTWndPara = 10
FFTWndChn = "time"
FFTWndCorrectTyp = "No"
FFTCalc = 0
FFTPhase = 1
As you can see above, the parameter setting for "FFTPhase" = 1 and I expected to see a phase spectrum being produced after running the function. However, this is not the case when I run it. Are there any other parameter settings I need to alter/change or is there a solution to this?
Can someone help? Thanks!
