08-28-2014 02:33 AM
i have a script include to an other one.
when i set a breakpoint into the included script an run my diadem
the debugger will make a break but don´t show me the line where i set the breakpoint.
the debugger jumps in to the last line of the included script.
in the normal script (from where i call the include file) the breakpoint work as i aspect.
i know the problem with the debugger if you close a function (it is showed only with one line) , than it do the same.
i have expaned all functions - and 2 weeks ago the system works without no problems.
the only thing what is new, i changed my laptop.
the MS Debuger Function ist installed.
would be great to get help
thanks
maik
09-29-2014 02:23 AM
Hi MaikThierer,
when I set a breakpoint in a function of a subscript and call this function from a caller script the debugger jumps to the set breakpoint. If you close the function the debugger only jumps to the function.
I can't reproduce your discribed behaviour.
Philipp K.
AE | NI-Germany
09-29-2014 02:38 AM
i think i found the reason.
the diadem debugger used a pdm.dll with the version 6.0.0.8424
and this version was still used after the installtion of the ms debugger.
i copied the dll version 9.0.30729.1 into the path where diadem linked to, now it works
09-29-2014 03:00 AM
Hi Maik,
I have the same problem. So i look for pdm.dll at my computer and i found some files with this name.
In which path do you exchange the file?
kind regards
Uwe
09-29-2014 03:06 AM
You can check the path
on my german version it is
Diadem Menüleiste -> Hilfe -> Info über... -> Script Engine
in english maybe (Diadem Menue -> Help -> Info About.... -> Script Engine)
here you can find the Debugger infomation
06-02-2015 07:51 AM
