Hello all,
I have the following issue with Datafinder and Diadem 10:
When I generate TDM files and the generation takes a longer time (minutes), it seems like Datafinder tries to index these while they are still locked by the operating system. As this doesn't work, a log file is generated and the Indexing Status is set to "eIndexedFailure". This also happens when I fetch these TDMs via ftp from a RT target.
Now, my problem is that after these files are accessible again, the only way I found to make Datafinder index them is to delete the whole index and reindex my whole data repository. Just doing an index update will not index these files, even if they are not locked anymore. Just deleting the log files does not help, either.
Does anybody have an idea how to solve this issue?
Error message is like this one:
fatal error (80) :Unable to open "D:\060522\060522_22-20-10_SchieneRoh_1s.TDX" to read! (Der Prozess kann nicht auf die Datei zugreifen, da sie von einem anderen Prozess verwendet wird.)
Thanks for your help,
Stefan
