Hi Walter,
thanks for the reply. I did install the latest application SP, but not the driver. Although I am not 100% sure it was the latest SP, I will check that tomorrow when I am back at the company.
The application gets the data from the measuring system via an Profibus-Server (OPC-Protocol). The measuring hardware isnt on the computer running DIAdem. The problem does also occur with simulated signals. I removed the OPC-In and Outputs to test the software on another pc and I got the same problem on that one.
I dont reload the DAC-Scheme, I just do a schemecheck every cylce. I did test reloading it though and it didnt help.
I did some further testing and the problem seems to be connected to saving the picture with picexport. Every time I call that function the gdi-objects raise by 2 (the displayed value changes but the maximum value raises by 2). The same happens when I use picprint as an alternative. I also tried various combinations with and without picdelete, picload or picupdate but only not saving the picture seems to stop the problem.
The picture itself is made up of static text and 5 variables that describe the current measured item (3 Strings and 2 Reals).
Right now I am running a test version where I use buttons to display the data and its been stable for about 2 days now.
I hope that helps tracking the problem down.
Best regards
Utz
