08-20-2007 10:12 PM
08-21-2007 03:07 PM
08-21-2007 04:00 PM
Sorry.
I'm running DIAdem 10.2 under Windows XP SP2 (with the most recent patches) on a computer with a Pentium 4 3 GHz processor with 1 GB of RAM. I installed DIAdem 10.2 using the default folder structure. The scripts will work as long as there is no error or the cancel is pressed on a windows dialog box that is called from my script. While troubleshooting, I added a msgbox in an If statement for the dialog cancel. The message box pops up signifying cancel was pressed and recieved in my script. After clicking OK to the message box, DIAdem crashed to the desktop.
Thanks in advance for any help resolving this problem,
AJL
08-23-2007 10:11 AM
Hi AJL,
I have personally noticed unexpected crashing in DIAdem 10.2 in only two scenarios:
1) I have programmatically opened a REPORT object with GRAPHObjOpen() but the script has terminated before closing the REPORT obbject. If I then do anything to force the REPORT panel to refresh, such as try to move any REPORT object, or if I try to configure that unclosed REPORT object, DIAdem crashes abruptly.
2) Trying to use certain commands in custom menus, which used to work in DIAdem 10.1, now cause DIAdem 10.2 to crash abruptly.
Any chance you're tripping over either of these wires?
Brad Turpin
DIAdem Product Support Engineer
08-23-2007 02:24 PM
Matthias Alleweldt Project Engineer / Projektingenieur | Twigeater? |
08-28-2007 06:16 AM
Matthias,
Please keep us up to date on any findings from R&D. One thing to note though, I have experienced crashes even when I do not call a SUD. DIAdem will crash when pressing cancel on a windows dialog box.
AJL
08-28-2007 09:12 AM
Hi AJL,
What sort of Windows dialogs? R&D can not do much for us until we can give them a repeatable scenario to reproduce the crash. I do not possess such a repeatable scenario-- until I do it would be unlikely for R&D to fix the problem. Any additional information you can provide would increase the chance that we can find a way to reproduce the behavior. Once it's reproducible on the developer's computer, it's usually a short path to the fix.
Brad Turpin
