First you need to define so called „Global Virtual Channels” in MAX (Measurement and Automation Explorer). All channels which you defined there can be chosen in “Driver-Inputs” for measuring data or “Driver-Outputs” for sending data to the hardware.
Then you can either load an example, select the “NI-DAQmx Driver” and drop it over an input block like “Random” – or define your own DAC scheme.
