03-12-2015 11:40 AM
I need to convert a *.sud file (which currently works in DIAdem 11) to DIAdem 2014. Need your help please.
When I execute the sud file, it gave the following errors:
Error in <graphTool.sud, graphDlg> (Line: 1411, column: 3):
SU event context:
Dialog_EventInitialize(...)
cbTestSet_EventChange(...)
cbPartNo_EventChange(...)
Type mismatch: 'SQL_Execdirect'
This is the section of the code in the SUD file:
Sub cbPartNo_EventChange(ByRef This) 'Created Event Handler
'Clear all of the listboxes since a new part number is chosen
guiObj.clearLB(1)
guiObj.partNo = cbPartNo.InterpretedText
'Query for serial numbers
T1 = "Select distinct a.serial_no from test_run_meas_channels a, test_runs b where a.part_no = '"&guiObj.partNo&"' AND a.test_date = b.test_date AND a.part_no = b.part_no AND a.serial_no = b.serial_no " & rfilter &passFilter
msgbox T1
sTime = Timer
Call SQL_Execdirect("T1") '==== LINE 1411
eTime = Timer
If logSpeed = 1 Then
fTime = eTime - sTime
fsoStream.Write T1 & vbCr & fTime & vbCr
End If
'Call sqlObj.SQLselect("distinct serial_no", "test_run_meas_channels", "part_no = '"&guiObj.partNo&"'"&passFilter)
Call sqlObj.SQLResultsToXBox(lbSerialNo, 1, 0)
If lbSerialNo.X.ListCount > 0 Then
lbSerialNo.X.Selected(0) = True
End If
End Sub
03-12-2015 12:42 PM
I found the answer. Need to register the gfsODBC.DLL in DIAdem 2014.
http://digital.ni.com/public.nsf/allkb/AA704980F461DD9386256C000064A1BF
