DIAdem
DIAdem 2010 Advanced Edition
Is it possible to do probabilty distribution calculation in DIAdem??
For a some analysis, i need FFT and PDF(Probability Distribution Function) calculations.
I got FFT but unable to get PDF...
Just wanted to know where to find that function in DIAdem 2010.
Regards.
(4,941 Views)
Hello Bijay,
DIAdem supports a lot of different statistic functions, but currently no distribution functions. The statistic functions are located in DIAdem ANALYSIS in the tool group "Statistics". In DIAdem REPORT you can create a PDF by opening the menu "File" --> "PDF export" or via command icon:
Greetings
Walter
(4,657 Views)
Hello Walter,
I needed that distribution function for some analysis.
Thanks for knowledge sharing.
Bijay
(4,636 Views)
Hi Bijay,
We can give you the standard normal distribution of a data set, but that's it.  What else do you want?
Brad Turpin
DIAdem Product Support Engineer
(4,604 Views)
Hello Brad,
Yes, that will be a great help. Currently i am doing that analysis in LabVIEW.
Bijay
(4,596 Views)
Accepted by topic author Bijay
Hi Bijay,
Here's an example you can run.  It uses older DIAdem 10.x functions, but it still works in DIAdem 11.x/20xx.
Brad Turpin
(4,588 Views)
