Hello all,
I would like to call in a TestStand sequence a step with a code module targeted to a DIAdem script.
I have some parameters (input/output) to pass to my VBS script.
The number and the type of the parameters depend on the VBS script to assign to the TS Step.
I think I should use the ActiveX server adapter provided by TestStand.
The DIAdem.TOCommand object seems to provide a method for running VBS script
Do you have any idea of the different solutions to pass data from TS to DIAdem?
Do I need to store my step properties in a file and read the properties
Thank you.
Matthieu G.
Eurilogic, France
