07-12-2006 03:29 AM
07-13-2006 02:47 AM
Hello!
The version of DIAdem you are using was released about the same time frame we bought Gfs and I have never worked with that version myself (only 7.x and later for my part). I talked to some knowledgeable guys at NI Germany though and even though they haven't used it either they could provide me some information. They checked out the read-me file for the 7.x release that says which devices is supported in that version and they are:
DAQCard 500, 516, 700, 1200 and AI16E4
These are all old boards and the board you are using is newer and will therefore not work in 6.x or 7.x of DIAdem.
08-11-2006 02:24 AM
A follow up...
I got Diadem 9,1 now, but the previous way of setting up inputs differ quite a bit. It seems that you need a full version of Labview (7,1 or later) in order to get any data recording in later versions of Diadem? Is this correct?
Furthermore, what would you guys say would be the best way of setting up a measurement with the following stuff available:
2 pcs NI DaqCard 6036E (PCMCIA) with BNC2110 connector racks, Diadem 8,0 and 9,1, VI Logger Lite, Labview 7 Express (demo version)
Purchasing Labview is a viable solution I guess, but getting it through our IT approval would be as much fun as doing a root canal. So any way of getting a good measurement setup based on Diadem would be preferable since we've got full license coverage on that software.
Johannes
10-31-2006 08:26 AM
11-02-2006 12:20 AM
Hejsan Johannes,
Jag är ganska övertygad om att ditt daqcard fungerar med "mät & analys" versionen av DIAdem 9, det finns dock en version av DIAdem för endast "analys" (kallad "TDM" =TechnicalDataManagement,som du kanske kör nu?) i båda dessa versioner finns det med en labview ikon för de som hellre använder det för mätning...(detta har inte jag provat utan jag använder DIAdems mätfunktionalitet).
När du använder ditt daqcard i DIAdem kan du välja mellan två olika sätt "singlevalue" eller "packetprocessing" det senare används med fördel om du behöver snabbare mätning.
Tjingeling!
