DIAdem
Creating a Bar Manager in the VIEW panel
Hey guys!
My experience with this forum was awesome (thanks to you guys), so I want to ask another question.
I've created a "bar manager icon(?)" to call and start a specific script, but since this script displays the results in the "VIEW" panel, I was wondering if there was a way to move this "bar manager icon(?)" to the "VIEW" panel.
To clarify,
I want to move what I created in the SCRIPT panel (Shown in attached image) to the VIEW panel's red box area (also shown in the attached image)
Thanks in advance!
Tim
(2,636 Views)
Accepted by topic author kmyan9
Hey Tim,
If you hold Ctrl+Shift and move your mouse over any button in the VIEW function bar, you can see a tooltip with the bar ID that can be used with the bar manager:
So if you want to add a button to the VIEWGroup bar you can do it like this:
dim oBtn
'create new button (action object)
set oBtn = BarManager.ActionObjs.Add("MyViewButton","CustomButton")
oBtn.Picture.FileName = "IconFile.ico"
'use path for script that will be executed when clicking the button
oBtn.OnClickCode.Code = "ScriptStart(""C:\Data\Script.vbs"")"
'use bar ID here and add new button at position 6
call BarManager.Bars("VIEWGroup").UsedActionObjs.Insert(oBtn,6)
In 2017 there's a new method AddMenuItem that makes it easier:
dim oBtn
set oBtn = BarManager.AddMenuItem("VIEWGroup", "MyViewButton", "ScriptStart(""C:\Data\Script.vbs"")", 6)
Hope this helps.
Christian
CLA, CTA, CLED
(2,598 Views)
Hey Christian!
Worked like magic, thank you!
-Tim
(2,590 Views)
