02-26-2014 02:50 PM
I have multiple channels that have a text value to them and I was using a Dict.add function to change the values to a Number so it can be plotted linearly. However I have had to create a seperate function for each channel in the data set. I want to generalize it more so it will go out and look a all the channels and compare the values to the dictionary's already created. I have attached a sample form of how I currently am doing the change and I have played with a new form called TxtToNum.vbs that is more generalized. I have 6 dictionary's that I am using in total as well if that plays into the task. I don't do a lot of script work and could really use some help.
Thanks - J
Solved! Go to Solution.
02-26-2014 08:41 PM
I continue to try and play with this but can't seem to get it. I am missing the logic somewhere. I am trying to take a text value and compare it to my dictionary and then set the number in the text value's place
Like "On","1" So my channels would end up being a numeric channel and my "On" would turn into a "1" according to my dict3.
UGGGG!
02-27-2014 12:03 PM
Ok, got it to work but now I have a TEXT channel still and need to convert it to numeric values. How can I add that to this script?
02-27-2014 07:53 PM
Hi Jcheese,
Unfortunately there isn’t a direct way to convert a string/text channel to a numeric channel that I can find.
If you’re just pulling out individual values,
CStr() converts a numeric to a string. CInt() or CDbl() will convert a string to an Integer or a Double.
If you need to convert the whole channel, you would probably need to create a second channel, initialized to the same length as the Text channel, and then loop through the channel. Pull the text value out of the existing Text channel, use one of the functions above to convert it to a number, then set the value at the same index in the new channel.
Here’s a reference for creating a channel and setting the values:
Kelsey Johnson
Applications Engineering
02-28-2014 07:40 AM
Hello JCheese,
please try this :
Dim sgCmd
sgCmd = "ch(""#1"") = Val(ch(""#1""))"
sgCmd = Replace(sgCmd,"#1","MyChannelname")
Calculate(sgCmd)
The text MyChannelname needs to be replace with the name of the channel you want to convert
This uses the DIAdem "VAL" operator on the whole channel
02-28-2014 11:50 AM
Hello and thanks for the reply,
I tried the script you copied and it changing the channel to a numeric channel however it turns all my values into "NOVALUES"
My attachment that I have on this post is a working script that I am running and I wish to add the conversion factor into that script so as it converts it to the dictionary key it changes the channel to a numeric channel. Does anyone know how I could write that to work? I am not that familiar with script to write this kind of file. I have added my old file that I used which did make a seperate channel and put in the values like I want but it takes a long time to run. I am going through sometimes thousands of rows of data.
02-28-2014 12:47 PM
Hello JCheese,
running your script I saw that for those channels where you got NoValues, your mapping from text to the desired Integer didn't work. So after your "ConvertTxtToNum" you still have text in the channel which is like "Reading Not Available" in channel 49. It looks like your mapping is incomplete. Val("Reading Not Available") returns NoValue. Do you plan to add teh missing text/Value pairs in your map or do you want those strings to be mapped to a standard value ?
02-28-2014 12:50 PM
JCheese,
to better explain whats going on:
If you would change your function to this :
Function ConvertTxtToNum(Channel) Call Channel.ChannelGroup.Activate for t = 1 to Channel.Size IF Dict3.Exists(ChT(t,Channel.Name)) THEN ' Compares value in channel to value in dictionary ChT(t,Channel.Name) = Dict3.Item(ChT(t,Channel.Name)) ' changes the Key to the Item in the dictionary Else ChT(t,Channel.Name) = "0" end if 'dict3 next End Function ' ConvertTxtToNum()
You will find that the functions using "Val" works as expected adn doesn't create NoValues anymore
02-28-2014 12:51 PM
If a value is not present in my dictionary, then I would like it to be set to 0.
02-28-2014 12:57 PM
The following should do what you want:
''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' ' Text to Numeric Channel ''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' if programrevision > 1129 then Dim Channel,State,Dict3,t,TXT1 IF Data.Root.ChannelGroups(1).Channels.Count > 0 THEN FOR Each Channel In Data.Root.ChannelGroups(1).Channels IF Trim(UCase(Channel.Properties("DisplayType").Value)) = "TEXT" THEN Call ConvertTxtToNum(Channel) Call ValChn(Channel) END IF NEXT ' Channel END IF ' Any Channels at all END IF ' Program Version Function ConvertTxtToNum(Channel) Call Channel.ChannelGroup.Activate for t = 1 to Channel.Size IF Dict3.Exists(ChT(t,Channel.Name)) THEN ' Compares value in channel to value in dictionary ChT(t,Channel.Name) = Dict3.Item(ChT(t,Channel.Name)) ' changes the Key to the Item in the dictionary Else ChT(t,Channel.Name) = "0" end if 'dict3 next End Function ' ConvertTxtToNum() Function ValChn(oChannel) Dim sgCmd Dim ChnNumber : ChnNumber = oChannel.Properties("number").Value sgCmd = "ch(""#1"") = Val(ch(""#1""))" sgCmd = Replace(sgCmd,"#1",oChannel.GetReference(eRefTypeIndexName)) Calculate(sgCmd) End Function
