Hello Julia,
can you give an example of what you are exactly trying to do?
I understood that the problem is that some of the users does not have access to the SRIPT module. Are you thinking of some special commands you would like to log or is your question more general?
Some of the ANALYSIS funbctions have the ability to copy the results to the windows clipboard, as variable or as value. Have a look at the dialog for the statistics or the regression for instance. They have this results... subdialog where you may configure this behaviour.
Unfortunately these dialogs are an exception and not all ANALYSIS function support this feature. But this is also becaus the result is a channel quite often and cant be stored in other variables than the data matrix.
But just tell me which function you are using maybe I'll have an idea.
regards
Ingo Schumacher
Systems Engineering Manager CEERNational Instruments Germany
