DIAdem
Converting Multiple TDMS files to Excel
Hi All,
I am trying to convert multiple TDMS files to an Excel format with a reduced sample rate. The TDMS files are sampled at 25kHz and I would like the Excel files to be 2.5 kHz.
I can do this manually for each file by loading the TDMS file, using the script below, deleting the original group and resaving the file as an Excel. Here is the script:
Call GroupCreate("Reduced Channels")
Call GroupDefaultSet(GroupCount)
ReducVal = 10 'Reduction value (total reduction = original/this value.
CalcXChn = 1 'Time base channel.
CalcYChn = "2-6" 'Channels in group to be reduced.
ClassNo = ChnLength(CalcXChn)\ReducVal
Call ChnClassXRedXY(CalcXChn, CalcXChn, CalcYChn, "Automatic", "Mean")
FOR i = 1 TO GroupChnCount(GroupCount)
  ChnName(CNoXGet(GroupCount, i)) = ChnName(CNoXGet(1, i))
Next
Ideally, I would like to have a user interface which allows the user to select the file(s) and have a program to reduce the sample rate and save it as an Excel File. Unfortunately, this I have not been able to acheive yet.
I have attached an Excel file that has been converted manually. Any help would be appreciated.
Message 1 of 10
(7,462 Views)
Deleting the original group and saving the file as an Excel File could be automated. You can also use the FileDlgShow command to allow users to select multiple files from a dialog box, then run your script on each file in turn. Adding these steps should help streamline the process.
Steven Gloor
Staff Customer Engineer - CTA, CLD
Message 2 of 10
(7,405 Views)
Thanks Steven,
I will give this a try.
Message 3 of 10
(7,387 Views)
OK,
Instead of converting to an Excel file, I would be satisfied with converting to a .CSV file.
I created a new script to convert the filelist to CSV, but I am not sure how to use the original file names (just replacing the .TDMS extension with the .CSV extension).
Option Explicit  'Forces the explicit declaration of all the variables in a script.
Dim i
If FileDlgShow(DataReadPath,"TDM Files,*.tdm","DataSelection",True) = "IDOk" Then
For i = 0 to UBound(FileDlgNameList)
Call Data.Root.Clear()
Call DataFileLoad(FileDlgNameList(i),"TDM","Load")
Call DataFileSave(FileDlgNameList(i),"CSV")
Next
End If
In particular, the statement "Call DataFileSave(FileDlgNameList(i),"CSV")" needs to do this I assume, but I am not sure about the syntax.
Thanks for the help.
Message 4 of 10
(7,360 Views)
Hi CVfactor,
Here's the code to use the folders and file name but not the file extension:
CsvFilePath = NameSplit(FileDlgNameList(i), "P") & NameSplit(FileDlgNameList(i), "N") & ".CSV"
Call DataFileSave(CsvFilePath,"CSV")
Do note that the CSV export will only export one Group from the Data Portal.  If you need to export multiple groups, one to each file, then we can use the DataFileSaveSel() command.
Brad Turpin
DIAdem Product Support Engineer
Message 5 of 10
(7,342 Views)
Thanks Brad, I'll give this a try.
Message 6 of 10
(7,336 Views)
I'm getting an error when trying this script (see attachment).
If anyone has any ideas what the cause of this is, I would appreciate any feedback.
Message 7 of 10
(7,231 Views)
Option Explicit prevents this from working.
Message 8 of 10
(7,229 Views)
From the image you attached of the error, it appears that CsvFilePath is never declared in your script (i.e. Dim CsvFilePath) and will therefore be undefined.
Steven Gloor
Message 9 of 10
(7,192 Views)
Yes, Steven you are right. Removing the "option explicit" statement also allows this script to work.
Message 10 of 10
(7,189 Views)
