08-24-2015 10:11 AM
Hi All,
I am interested to know how to extract interpolated contour plot data in Diadem. It seems Diadem can create countour plots from 3 variable data and interpolate this data,
but I cannot figure out how to get access to this data.
For example, in the file "Raw Parameters" has the 3-D plot data and in the file "Contour Map" you can see this data is plotted with interpolation. I can also plot the values
for each point on the interoploated data surface but I'm not sure how to export the full mattrix.
Any help would be appreciated.
CVfactor
08-25-2015 10:03 AM
Hi CV,
Unfortunately there is no way to access the automatic contour lines the "Characteristic diagram" creates. However, you can calculate any contour plots you want with the "Calculate Contour Lines" function in the ANALYSIS panel, and the resulting channels it creates are available in the Data Portal.
Brad Turpin
DIAdem Product Support Engineer
08-27-2015 08:17 AM
Thanks Brad,
What I was trying to do is extract the mattrix data from the original triplet data that the contour plot was created from. I see there is a "3D" tab under analysis and I've
been playing around with this. I was not able to convert the triplet data to mattrix data so that it matches the original plot. The only way I can create a mattrix was by
manually picking the points from the cursor (see attachment).
So my question is when ploting a contour plot it seems like Diadem interpolates this data to create the plot. I'm not sure the interpolation setting that are used.
If there is no way to do this my back-up plan is to try to create a script that can extract the data from the cursos as it scans across the plot.
Any feedback is appreciated.
08-27-2015 11:23 AM
I figured out that Diadem naturally selects SISPL as the interpolation method. This can be reproduced in the "3D" tab under analysis. So to convert from triplet to matrix, you must use SISPL interpolation.
