DIAdem
Concatenate TDMS files for Diadem 14.0
Hii guys,
I have TDMS files  which have same properties except  they r generated at different time slices.
is there a  plug and play way to concatenate them  in DIadem 14.
I did check the other threads but they all included Scripts.
Can we acheive it without scripts.
regards,
akshay
(3,048 Views)
Since DIAdem 2015 there is an interactive way.
  • Select multiple files in DIAdem Navigator or File Dialog
  • Pick Append as loading mode
In versions older than DIAdem 2015 there is an example that offers an interaktive way after the files where loaded.
It can be found at:
Help > Examples > Examples > Creating Scripts > Scripts > Concatenate Channels
If you open ChnConcatenation_Main.vbs you can assign it to one of the diadem Script start buttons and use it interactive.
(3,035 Views)
Hi akshay,
If you really mean "properties" and not "channels", then you should query those TDMS files in DIAdem NAVIGATOR, then configure the Search Results section of the NAVIGATOR to show the properties you're interested in as columns (probably including the File.DateTime property).  Then you can click on those Search Results column headers and drag them into the Data Portal.
Brad Turpin
DIAdem Product Support Engineer
(2,949 Views)
