09-21-2006 10:25 AM
09-21-2006 11:41 AM
Hi Sam,
the reason for your problem is the DAT header file. The stored values for
min/max of the channels are not exact. There are some minor differences. If
DIAdem loads the data it uses the stored min/max values if they are available. The
easiest way to solve this problem is to recalculate the min/max values. You can
use the command
Call CHNCHARACTERALL()
Despite we are using a tolerance to find the min/max values these differences
are to high, but after the execution of this command the ChnTMinTMaxCalc
calculation is working fine.
Stefan
09-21-2006 12:41 PM
