07-07-2015 11:11 AM
Hello i must Concat any Groups with any Channels
Group 1 to 11 are the Basic Groups, Group 12 to 22 are Groups with the same Structure.
I tink i make a Loop for all Groups and into this loop a second loop with the Channels in this Group with the
GroupChnCount to count the chanels in the Group
the Offset ist the difference to beginn the Second Groups
the Code
'-- VBS-Script-Datei
'-- Neu erstellt am 07.07.2015 16:58:58
'-- Ersteller:
'-- Kommentar:
Option Explicit 'Erzwingt die explizite Deklaration aller Variablen in einem Script.
Dim Groupindex,GroupindexHigh
Dim Kanalindex
Dim Endindex
Dim Offset
Offset=11
For Groupindex= 1 to 11 'Group
Endindex=GroupChnCount(Groupindex)
GroupindexHigh=(Groupindex+Offset)
For Kanalindex= 1 to Endindex
call chnconcat(cnoxget(Groupindex,Kanalindex),cnoxget(Groupindex,Kanalindex))
Next
Next 'Group
greetings Thomas
07-14-2015 07:00 PM
Hi Thomas,
Looks pretty good-- I think the only thing you're missing is the "GroupindexHigh" in the second parameter:
Call chnconcat(cnoxget(Groupindex,Kanalindex),cnoxget(GroupindexHigh,Kanalindex))
Note that in the next couple of versions DIAdem will stop supporting the old channel number approach, so the CNoXGet() command won't work for much longer. This is an example of the new object approach:
iMax = 11 For i = 1 to iMax 'Group Set FromGroup = Data.Root.ChannelGroups(i) Set ToGroup = Data.Root.ChannelGroups(i+iMax) jMax = FromGroup.Channels.Count For j = 1 TO jMax Call ChnConcat(FromGroup.Channels(j), ToGroup.Channels(j)) Next ' Channel Next ' Group
Brad Turpin
DIAdem Product Support Engineer
