12-11-2005 08:13 PM
Hello, I am trying to use a matrix of Check Boxes in a SUD and I ask myself if it is possible to change a property of the table object to make that the cells appear like one check box and later obtain its true or false value using the value property. Is this possible?
12-12-2005 08:37 AM
12-14-2005 10:08 AM
Hello, Brad.
I am making some measurements that I want to compare in a set of graphics. Each measurement consist in a file with sixteen channels. I want to put the name of the channels in the first column and the name of the file in the first row of the matrix. In order to get the desired graph, the "user" of the dialog only needs to select the channel of the desired files that he wants to print in a report. It is as easy as put a "1" or a "0" in the appropiate cell, but it should be more aesthetic and friendly to have check boxes. I was thinking in a table similar to the Data Window of Diadem, but with several check box columns.
12-14-2005 12:15 PM
I created a table (called "MyTable") in a SUD dialog and in the "OnSelChange" sub, I have this:
If MyTable.SelectedCells(1).Column = 1 Then
12-14-2005 12:15 PM
12-14-2005 12:15 PM
12-14-2005 12:15 PM
12-14-2005 12:15 PM
12-14-2005 12:18 PM
Wow, very sorry about that! I pushed the space bar and suddenly I posted many times! This is what I was going to say:
I'm not sure if this is exactly what you want, but here is something I tried:
I created a table (called "MyTable") in a SUD dialog. In the "OnSelChange" subroutine, I have:
Sub MyTable_OnSelChange()
Dim This : Set This = MyTable
If MyTable.SelectedCells(1).Value <> "X" Then
MyTable.SelectedCells(1).Value = "X"
Else
MyTable.SelectedCells(1).Value = ""
End If
End If
End Sub
(you will not need the first two or last line). What this does is put an "X" in the first column when the user clicks on it, and then takes it away with the next click. So I'm not sure if this will be helpful or not, but I thought I would mention it.
Julia
12-15-2005 12:41 AM
Thank you very much, Julia. As a matter of fact, to put "X"s (to use the keyboard) is what I am trying to avoid. I made something near to what I am trying to do with a table, but with an array of check boxes using the set function at the general declarations; something like this:
Dim ArrayCheckBoxes(16) ' For example
Set ArrayCheckBoxes(1)=CheckBox1
Set ArrayCheckBoxes(2)=CheckBox2
And so on. It was useful, but from my point of view impractical, because the code for process the information is not so concise and that what's I was looking for something better.
I really appreciate your help, and I hope you can find useful my method for your application.
Greetings from Mexico.
