DIAdem
Cannot create storage target
I regularly receive this error message when trying to save a file that already exists - that is to say, overwriting an existing file after modifying it:
When it occurs I simply press CTRL+S and save it that way.
I'd be grateful for any clues as it means nothing to me.
Regards.
Message 1 of 17
(7,257 Views)
this message occurs, if the file is write protected or if there are no write permissions to the folder or path.
For this reason, CTRL+S will not work to overwrite the source file.
The path "y:\..." could be a network path, containing write protected source files.
Could you check this please?
Regards
Message 2 of 17
(7,232 Views)
Hi Simon,
Could you list the steps you take to see this message? Is it just saving from the file menu, or are you doing this with a script? Perhaps then we can replicate this issue.
It looks like you are saving to a network mapped drive, does this occur on local files too?
Ian S
Applications Engineer CLA
National Instruments UK&Ireland
Message 3 of 17
(7,230 Views)
The steps I take are:
Open .dat file
Modify
Press the Save TDM File As button
(File saves successfully on all occassions)
Open .tdm file
Modify
Press the same button
Error message occurs.
However, this does not always occur and I haven't been able to rectify it manually for the purposes of this diagnosis. I always use CTRL+S as the solution to the problem (contrary to the statement from ThomasWH).
The path is a mapped network drive where the vast majority of my work is saved. I couldn't say if the problem happens to locally saved files because I can't get the problem to occur at my command.
Regards.
Message 4 of 17
(7,217 Views)
Hi Simon,
I've tried to recreate the problem without any luck (perhaps not surprising, as it would be more widely reported if it was that easy to occur).
I found one other reported instance of this problem where it was also on a server machine, and one where the save was on the 😧 drive, so I'm not sure that the remote save is causing the problem (saving on network is a common scenario).
You could try repairing DIAdem which may solve the problem, but if the CTRL+S is working ok for you, it might be best just to continue with that for the future.
Ian S
Message 5 of 17
(7,175 Views)
This happened to me today, did you found any solution?
Message 6 of 17
(5,362 Views)
Not yet I'm afraid. It also happens to some of my colleagues but we haven't learnt why it occurs yet.
Message 7 of 17
(5,350 Views)
Dear,
I am working with a script to save the data in the dataportal as a csv file. It was saving the file normally and the I add some more info to put in the header of the file and after that I am getting the same message.
The script is finished.
231 14:03:37 Error:
Cannot create storage target.
Any idea? The target folder in my case I am sure is not protected and do not have writting prohibitions...
Please help.
Message 8 of 17
(5,053 Views)
Hi Maria,
The csv DataPlugin that installs with DIAdem, called "Textfile - Auto detect (*.csv)" in the "File>>Save as" dialog, only writes the name of each channel and all the channel values.  It does not write any other header information.  It also only writes channels from 1 Group in the Data Portal.
How were you trying to add information to the header of the *.csv file?  Were you creating properties in the Data Portal and hoping the DataPlugin would write them to the *.csv file, or were you manipulating the *.csv DIAdem created interactively in an application such as Notepad?
Brad Turpin
DIAdem Product Support Engineer
Message 9 of 17
(5,041 Views)
Dear Brad,
In fact I was using one script I found in the forums, created by you I think... it add the units under the names of the channels and then create the csv file...
ASCII Export with CSV Headers
I just reinitialize DIAdem and it stops happening... But don't know if the error will come again...
Message 10 of 17
(5,034 Views)
