DIAdem
Best method to reduce high frequency data
I am receiving data recorded at approximately 5 Hz.  In DIAdem I would like to calculate a "1 Hz mean" of my 5 Hz data, so that one point *in the new channel) would represent the average of the last 5 points (from the original channel).  Is there an already-defined function in ANALYSIS that could help me do this?  I have tried a few different functions, but am not sure exactly how they work, and would prefer not to write a script to make this calculation.
Thanks!
Julia Moeller
Message 1 of 9
(4,874 Views)
Hi Julia,
I am afraid I can partly help you. To reduce the frequency from 5 Hz to e.g.: 1 Hz you can use the function "File>>>paste from file", then select the file and after "Reduce lines >>>line reduc..." . You could set the line interval width for each 5 lines, so the data will be reduced.
Hope it helps a little bit.
Rodrigo (Brazil) 🙂
Message 2 of 9
(4,871 Views)
Hi Julia,
Please use the Reducing Classification in the Statistics function bar. Provide one x- and one y-channel and select Mean as reduction mode. In the classes dialog box keep the default settings and insert "Channellength/5" as No. of classes.
Ralf
Message 3 of 9
(4,854 Views)
That's great, thank you Ralf
Message 4 of 9
(4,843 Views)
i also need to reduce my data of a certain group and found this thread. i tried to type "Channellength/5" as No. of classes but i get an error message "cannot assign Channellength/5 to the integer variable   Assignment:< CLASSNO=Channellength/5>
what do i have to type to get every 10. value respectively the mean value of 10 values.
if i tpe 5 as No. of classes my channel length is only 5. mi channel length is 18000, if i type 1800 as no of classes will i get the mean value of 10 following values?
Message 5 of 9
(4,202 Views)
Hi All,
Normann and I figured things out via email, but for anyone else searching for this thread, what I suggested to him was that
the easiest way to average together each window of 5 values to resample each signal is to load the data set with data reduction. Instead of dragging the data file into the Data Portal, right-click on it and select the "Data Reduction..." context menu, then select the data reduction parameters you want... in this case to calculate the mean from each window of 5 points.
Brad Turpin
DIAdem Product Support Engineer
Message 6 of 9
(4,177 Views)
Hello Brad,
I realise this topic is a little old but i'm hoping you can help.
  • I have a number of channels from a TDMS file that is continully being added to from a labview VI,
  • periodically I run a script in Diadem to reload all the data and perform analysis and reporting,
    • each of the channels are written at 1 per second,
  • I would like to take this data and average 60 records per minute
    • so rather than 3600 records per channel for each hour, i would have an average of records spilt up to 60,  1 minute records
  • then i will create a seperate channel that is 1 minute average of the last 60 records
 looking at the solution above i am wondering how this could be scripted.
Hope you can help and thanks in advance
Nick
Message 7 of 9
(3,712 Views)
Nick
The script example to do a reduced data load is :
Dim oMyElementList
Set oMyElementList = DataFileLoadRed("Example.tdm","TDM","","IntervalWidth",100,eInterMeanValue OR eInterFirstValue)
Call ChnSum(oMyElementList, "ChannelSum")
Look up the help on DataFileLoadRed
Paul
Message 8 of 9
(3,698 Views)
Thanks Paul,
I'll give it a go .
regards
Nick
Message 9 of 9
(3,679 Views)
