02-18-2014 06:51 PM
In my report, I am displaying the first 3 minutes (of a 10 hour recording) for a channel on a 2D chart. I've set the scaling mode to Completely automatic. The chart is scaled according to the overall peak value (around 40000), not the peak value for the 3 minutes (around 200) being displayed. Is there a way to auto adjust the scale for just the first 3 minutes through a config setting?
02-19-2014 04:52 PM
Hi ric.winters,
You could create a new Data Channel that just has the first 3 minutes of data in it. Then you could plot that instead of the entire 10 hour recording. This way the auto-scaling would be more meaningful.
02-19-2014 04:55 PM
Hi ric.winters,
I'm not aware of a graph setting to autoscale the Y axis to just the values displayed by the current X axis. I think your only option is to use the StatBlockCalc() command to calculate the Ymin and Ymax values of the row range that corresponds to the displayed X axis region.
I can help with this if you need it,
Brad Turpin
DIAdem Product Support Engineer
02-19-2014 05:03 PM
I thought about doing that, but I can't create a new channel with the same name right? I use the channel name on the Y axis, so it wouldn't be the same as the original name.
02-20-2014 10:02 AM
Hi ric,
You don't have to create a new channel to do what I'm suggesting. The StatBlockCalc() command in DIAdem is one of the few that takes a row range parameter, so you can calculate the max and min values of a particular (X-axis) time range by providing the corresponding row range to the StatBlockCalc() command. The min and max values are placed in global variables-- no new channel needed-- in fact I'd recommend you avoid creating any channels with the StatBlockCalc() command, like this:
IF Xch <> "" THEN P1 = PNo(Xch, X1) P2 = PNo(Xch, X2) ElseIF ChnWfKey(Ych) THEN Start = ChnPropValGet(Ych, "wf_start_offset") Delta = ChnPropValGet(Ych, "wf_increment") IF Delta = 0 THEN Delta = 1 P1 = CLng((1 + X1 - Start)/Delta) P2 = CLng((1 + X2 - Start)/Delta) ELSE P1 = CLng(X1) P2 = CLng(X2) END IF Size = ChnLength(Ych) IF P1 < 1 THEN P1 = 1 IF P2 < 2 THEN P2 = 2 IF P1 > Size-1 THEN P1 = Size-1 IF P2 > Size THEN P2 = Size FOR i = 1 TO 23 StatSel(i) = "No" NEXT ' i StatSel(4) = "Yes" ' Min StatSel(5) = "Yes" ' Max StatResChn = FALSE StatClipCopy = FALSE StatClipValue = FALSE RowRange = P1 & "-" & P2 Call StatBlockCalc("Channel", RowRange, Ych) MsgBox StatMin & " ... " & StatMax
Brad Turpin
