DIAdem
6211 DDC_StorageCouldNotBeOpened The storage could not be opened
The DDC lib got an update that fixes the given behavior.
ddc lib description
Please update your version and the behavior should be gone in 64 bit.
Message 11 of 13
(2,371 Views)
I am not sure why but it doesn't work! Is the nilibddc.h for 32bit? Normally the 'include' folder contains two nilibddc.h, one 32-bit and one 64-bit. The later is even called nilibddc_m.h
On the other hand, I did replace the tdms_ebd.dll with the one from the excel folder, as you suggested, and everything is working fine now.
Message 12 of 13
(2,356 Views)
See you are refering to the matlab example including the ddc lib.
If you update the example by just extract the new ddc version into the same folder it should also work.
See if we can update this example too.
Current solution before update is available
  • download example
  • download ddc lib
  • exract ddc lib into example folder and overwrite old ddc version
Afterwards it should work using the new ddc lib. The *_m.h headers should also work with tne new ddc version.
Message 13 of 13
(2,336 Views)
