03-02-2015 04:30 AM
I have a problem with a 3D Axis System, bar type.
Everything works fine as long as the y-channel contains more than one value (meaning there is more than one z-channel too).
But when my y-channel has only one value, and there is only one z-channel, the axis system goes blank (there is just an empty white field with a thin outline).
I don't understand why it doesn't work that way. The length of my one z-channel is the same length as my x-channel, as it should be.
03-03-2015 04:47 AM
HI,
could you describe your hardware and software setup?
If this is possible please attache your project.
03-03-2015 12:17 PM
Hi maliya,
Would you please submit this small data set and your *.TDR file that contains the REPORT configuration you're using?
Brad Turpin
DIAdem Product Support Engineer
03-04-2015 01:46 AM - edited 03-04-2015 01:46 AM
I can't submit the exact data I was working with but here's a small example that illustrates the problem (data and report file).
03-04-2015 08:50 AM
Hi Maliya,
you need at least 2 values in each axis to show it in a 3D Axis System.
Best regards
