DIAdem Idea Exchange
About DIAdem Idea Exchange
Do you have a feature idea for how to improve NI DIAdem? Submit and vote on ideas now!
  1. Browse by label or search in the DIAdem Idea Exchange to see if your idea has previously been submitted. If your idea exists sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea. Note: the DIAdem Idea Exchange is not the appropriate forum to submit technical support questions.
  5. Give kudos to other ideas that you would like to see implemented!
The DIAdem R&D team is committed to reviewing every idea submitted via the DIAdem Idea Exchange. However, we cannot guarantee the implementation of any DIAdem Idea Exchange submission until further documented.
Top Kudoed Authors
User Kudos Count
1
1
box plot
Hey everyone,
There should be an integrated feature in DIAdem to create Boxplots. You can already find the min Q1 median Q3 and max in the analysis portion. I have not been able to find a good way to make a boxplot in DIAdem, and it's a very clunky process in excell. I've had to use DIAdem to process data then export the interested channels to excel to make acutal boxplots, which still requires a lot of manipulation.
To do this in excel you create a modified boxplot based on the difference in the five number summary. These numbers are put into a stacked boxplot, then the settings are played with to give the finalized look of a box plot.
The Differences plotted as a stacked bar plot looks like the following with borders on and the bottom and top sections made invisible with error bars to mark the min and max values
There should be a way to do a similar process, or even an automatic box plot creator in DIAdem.
Let me know what you think,
Sadie
