Unfortunately, I do a lot of work with non-Metric units, but generally take the measurements in Metric. I'd like to be able to have the Y2 axis display converted units without creating a new channel, adding to the graph, adding a new channel to my graph, modifying the begin/end points so that the new signal perfectly matches the metric version, etc.
For example, if I had position vs time, and my Y1 data is in meters, I'd like the option to add the Y2 axis in feet from the graph setup.
Thank you for your request.
Since DIAdem 2012 we support an individual unit conversion for each axis in a 2D axis system. Please use the setting of “Curve and Axis Definition”, “Axis Parameters” – “Unit”
Greetings
Walter
