DIAdem Idea Exchange
About DIAdem Idea Exchange
Do you have a feature idea for how to improve NI DIAdem? Submit and vote on ideas now!
  1. Browse by label or search in the DIAdem Idea Exchange to see if your idea has previously been submitted. If your idea exists sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea. Note: the DIAdem Idea Exchange is not the appropriate forum to submit technical support questions.
  5. Give kudos to other ideas that you would like to see implemented!
The DIAdem R&D team is committed to reviewing every idea submitted via the DIAdem Idea Exchange. However, we cannot guarantee the implementation of any DIAdem Idea Exchange submission until further documented.
Top Kudoed Authors
User Kudos Count
1
View: Table scrolling simultaneously with the 2D-Graph
it would be helpful to have the following option in the View:
In case of moving the cursor through the 2D-Graph, I would like to have the table scrolling automatically the same way with highlightning the values of the cursors position.
Kind regards
Bernhard
(Diadem 2011)
4 Comments
Member MarcusP
Status changed to: In Development
Member dietfons
Status changed to: Completed
Feature is released with DIAdem 2015
Member Radek_Codr
Please, where could I find the feature in DIAdem 2015?
Thank you.
Member MarcusP
In order to use the synchronisation between cursor and table, first switch the cursor mode to "Curve Cursor" to make the cursor follow the actual curve and then turn on "Synchronize with Cursor" via the channel table context menu.
MarcusP
