DIAdem 2018 ships with the ability to color the GPS map trail based on the value of a channel in the Data Portal. If you still want the breadcrumb dots, please describe those in detail in a new request.
Brad Turpin
DIAdem Product Support Engineer
All,
I am currently trying to use the new mapping feature in DIAdem 2010
to create a map of a drive route. I want the map to contain a "bread
crumb" trail of the route. I also need the ability to change the each
Lattitude/Longitude point to a specific color depending on another
channel of data. I have a report that does a similar task but I use
MapPoint and Labview to create the map and then export it as an image
and use DIAdem to grab the image and attach it into the report. I
thought I might be able to leverage the DIAdem 2010 mapping feature if
possible.
I have attached a map of what I am trying to do in the DIAdem forums at the following location.
I second this concept. I would like to be able to plot a route from an NMEA file on the map area and color code certain sections of the route condionally based on other measured data (i.e. when acceleration above 5G make the route red, otherwise route color green).
In our Drive test tool, part of Summitek Instruments Spectrum Monitoring software, we use a third party mapping application. I looked at the free mapping solution that Diadem is using. In order to use for our application, we need the following features.
Put a picture( bitmap) at a specified latitude and longitude.
What we can do currently in DIAdem that satisfies part of what you want is to create a standard XY plot of the Latitude channel vs. the Longitude channel. That shows the 2D route that is traversed, and it also updates with a crosshair (+) symbol as you move the cursor on other 2D graphs in VIEW.
Brad Turpin
DIAdem Product Support Engineer National Instruments
I also have the same requirement. Most GIS applications such as google earth, map point, etc. offer the ability to plot tracks, waypoints, map markers at each data point etc.. My expectation for DIADEM GIS functionality is that it would do the same as an overlay on the map. My users would like to see a plot of a vehicle's course on a map over a specified period of time.
I have the same idea. When you have made a measurement with GPS positions included in your data, it should be possible to report or view a measured parameter on these GPS positions. It should be possible to give different colours to the parameter values. E.g. I have made some vibration measurements on a tram with GPS positions. When it is possible to give low vibrations levels a green colour and high levels a red colour you can easy spot bad sections of track. It is combining two functions DIAdem already has: GPS maps and 3D characteristic diagram.
Hi Everyone,
Brad Turpin
